Here is my write-up for The 2013 basic IMAC sequence:
Aileron Roll
Humpty Bump, Pull to vertical upline, Pull half loop over top to vertical down line, Center half roll, Pull to upright exit,.
Reverse Teardrop, Pull to a forty-five upline, Pull a five-eighths loop around to a vertical downline, Pull to an upright exit.
Reverse Sharks Tooth, Pull to a forty-five upline, Center half roll to inverted, Pull to vertical downline, Pull to upright exit.
Inside Loop, Pull inside loop back around to level.
Hammer Head, (stall turn) Pull to a vertical upline, Hammer Top, Establish vertical downline, Pull to upright exit.
Half Cuban Eight, Pull five-eighths loop around to an inverted forty‐five down line, Center half roll to upright, Pull to upright exit.
Sharks Tooth, Pull to a vertical upline, Pull to inverted forty-five down line, Center half roll to upright, Pull to upright exit.
Immelmann, Pull half inside loop, with a half roll on exit, Exiting upright.
Two Turn Positive Spin, Wait for the stall then do two full spins, Establish a vertical downline, Pull to an upright exit(remember to draw a line after the maneuver before exiting the box).
