I got a few more things accomplished last night. I made a choke lever so I can just reach through the hole in the front of the cowl to set the choke. I used some BVM Poly Ply I had laying around and CA'd three pieces together for thickness and cut a slot in the back end to slide over the shaft and shaped the main part. I then used a 2-56 and a locknut to hold it on.
I'm using Secraft wing bolts. They don't fit the Chinese blind nuts in the wings very well, they're pretty sloppy, so I JB Welded them in. I also drilled a #55 hole in them to accept a hitch pin, I did this on my Pilot Edge and it has worked great. The Secraft nuts spin on super easy, which means if they should happen loosen up in flight they would spin off easy too, but the hitch pin stops that and only takes a second to install during assembly at the field.
I also had to do a little fiddling to make the hatch bolt on, The holes didn't align very well with the blind nuts so I took care of that. I don't need any more hatch blind nut issues.
The plan is to maiden it Sunday morning. I still have quite a few things to do, but I have tonight and most of the day tomorrow to do them. I want to weigh it, balance it, set the throws, match the aileron servos, balance the prop, test run it and mount the batteries. I'm hoping it will not be tail heavy, since I really want to mount the batteries next to the receiver in the rear of the hatch opening so they'll be easy to take out to charge. Unfortunately I don't have room at home to put the wings on, so I'll need to do a lot of it at my shop.
