fencelake
The next step was to add the stringers to the aft section of the fuselage.  A couple of things about this:  First, for my particular modifications the side stringers connection to the rear of the cabin top was very important because the former F4 will be removed.  So I was pretty careful with this. Second, the installation of the stringers was a little more tedious than I thought it would be because of the bends, so I actually glued certain sections in stages and then shaped it as it dried.  I started with tape but instead, I had some dacron line (leftover from renewing my hi-start) which I used to secure pieces in place, and this works great!  You can tie it off tight, it doesn't stretch or come undone, and when the pieces dry, simply cut it away.
