Got out early evening  today (5pm) and finally maiden of the MXS! Aura 8 off and low rates the plane flew rock solid smooth only requiring some up (4clicks) elevator trim. Threw the switch to low rate gyro and commenced to do the smoothest rollers I have ever done! Threw the switch to high rate gyro and HA KE to the deck steady as a rock! Hovers great but need to address a small amount of trim on the rudder and elevator only. The wind got a little "swirly" and you could see the plane get bumped a bit  but once the Aura 8 is switched in it was smooth steady flying! Me LIKE! I was the only one there today so pictures on the ground and not flying.
I wish others who doubt this system where there to see a huge difference in stability. It does not fly the plane or even self level it just makes it rock solid smooth in harriers, knife edge, etc... I can see where IMAC guys would like this system!
