Redwing 50cc slick 540 build log
Plate already fixed, moving servos to the other position.
SnowDog
Good to know....sorry to hear about the damage...that tells me how I should mount the Aileron servos in my 50cc extra.
That's why. I surface mounted mine.. but hey at least yours is in one piece uploadfromtaptalk1403488123305.jpguploadfromtaptalk1403488133358.jpguploadfromtaptalk1403488144341.jpguploadfromtaptalk1403488158160.jpguploadfromtaptalk1403488169146.jpguploadfromtaptalk1403488180706.jpgI got locked out some how.. very odd for futaba.. wasn't battery failure cause my ibec was still giving my Ingition power
Fixed it just in time to hit the end of the allowed gasser time at my silly club. I did weight it. just under 16 pounds with the GT60 and the tru turn spinner, no fuel. It was clearly nose heavy, so I will be using the stock spinner next time out. The OS is a heavy motor, so I can see how a DLE-55 one can be 15.5 lbs with a few other minor tweaks.
I used a powersafe RX which is a bit heavy with 4 satellites.
2 fuel filters so you could delete one of them (1 on fill and 1 on vent)
Not use all the techflex I did.
smaller batteries, I am using 2s 2600s
I used thicker pull pull wire and tensioners.
SnowDog
that's a real shame Blake....would really like to know what failed. You say you got a lockout on Futaba? that's pretty rare, I would guess.
