Enterprise
No split cowl on the Pilot.  Split cowls are not as common on 30% as on bigger sizes.  The easiest cowling I have is the one on the EF 104 Extra as it has all of three bolts.  My 88 EF Edge is not too bad with 4 tabs, but it is not as robust as other designs.   The 89 Slick is plain painful as they bolt in from the rear inside the fuse.
The worst ever has to be the H9 35% Extra. 2 of them had to be screwed in from the side down very long tubes that you could never get the bolt to line up in.
I would not base a buying decision on the cowling arrangement as once you are setup, you don't take it of much, especially if you make a hole to get access to the needles. The Smith's told me how they do all sort of holes in their setups to get around taking the cowling's off.
The removable rudder is a nice feature however. I know my buddies Pilot has a removable rudder as well, but he might have modified it. I will have to ask.
