3dhs 92" Edge 540
Status
Not open for further replies.
looks good Gary....I would suggest you get a longer throttle arm...I doubt you are going to get the resolution you need with an arm that short.
TBM makes one; I used it on my DLE-30.
The arm isn't removable like on a DLE. :(
djmoose
:facepalm: even IF I could get it off, then issue is there is NO extra clearance inside the engine housing for a longer arm:
How about on the opposite side of the carb where the other end of the throttle rod extends?
I would say use it how it is. The resolution IMO won't be terribly noticeable. I've been using stock arms for years with no trouble.
If you'd like to get a longer arm on it, try switching to the other side of the carb to find more clearance if possible, and proceed with the instructions about the arm posted earlier.
Just my .2
Thanks
Brian
Status
