Ohio AV8TOR
Just Do It
My DA-70 came in yesterday for my new 91"  Wow what a beautiful motor.  Did not quite get EF's manual with cutting 2 of the elevator hinges though.  First off they do not hit the tube in the stab and you can put a hinge at the back and see it.  If it did hit you would need to cut 3 hinges not 2 because 3 are in the area of the tube.  Regardless I cut them to be safe.
For those that are using the DA=70 I saw on RCG where Chris said there is a servo cutout in the rear for Push pull for use with the DA-70, is that the setup you did. I think I like push pull better being more direct.
