Scale Balsa USA Camel F1
Tseres
Have not taken the plans out of the box yet. That may be a good idea. May give us a better look at things.
thepamster
If you remove the plans from the box does that mean that winter has officially started? If so maybe you should leave them in the box a little longer. Lol.
Do-rag
thepamster;16100 wrote: If you remove the plans from the box does that mean that winter has officially started? If so maybe you should leave them in the box a little longer. Lol.
If that is the case leave them in the box and build it without plans.
Tseres
To late. It looks like my fist suspicions were correct.
Tseres
Do-rag;16112 wrote: If that is the case leave them in the box and build it without plans.
Never fear. I rolled them back up and taped the box up. Be about a month before I open it again. Maybe later if the weather is good. LOL.
thepamster
Well my first thought would be to leave the landing gear mounted to the wing and only unbolt the front portion. Since the front of the wing seams to be only attached by dowel this would be just like having 2 additional wing bolts that would attach the front part of the landing gear.
Tseres
My thought is the opposite. Need to leave the gear on for ease of transport. I may redesign the wing to be a 3 peace.
I knew I shouldn't have opened up the box. My brains on fire. LOL.
thepamster
Yep, that is why I was wondering about the 1 or 2 piece wings. That will takes some engineering making it a 3 piece. But I know you are the one that can tackle that task for sure.
Isn't there also an arf version of that plane? If so I wonder what they do on that one.
Tseres
I've never seen an Arf version. It would be great if there was one.
Maybe I can send the Wing planns to Terry and he can Modify the planns on his computer.
wecoyote
I have a Fly Baby that have the landing gear mounted the same way. I unscrew the straps that attach the gear to the wing, hinge the gear forward to remove the wing then tie the gear back up with a piece of string for transport. I'll try to get a picture or two of it to explain better.
