Good to see you back and building again. I thought you did not electrical drive systems and you sold most of it. Anyway have a question I see you a QQ-Aurora in the plane. Would you be so kind to elaborate on how it works with a single JR satellite receiver. Thanks
With the SRXL serial bus DSMX remotes plug in to the "A" serial port of the Aura 8. There are two of these ports marked A and B. You would plug a bind plug in to servo port S8 of the Aura 8 for the binding process. The remote supports up to 8 channels with intermediate range capability which is great for "Park Flyer" size air craft. If you want to use an "extended range" remote receiver then a second remote can be used by plugging it in to port B or use the DSMX "Quad Racer" version (same price as DSMX remotes) remote receiver which is designed to work with all the flight control boards such as Aura 8, NAZE 32, KK2.5, Open Pilot's ccdpm system etc... Note: Flex innovations has not yet made a quad program and the Aura 8 is specific to fixed wing aircraft.
. It pulled up some of the black paint (easy fix) but also pulled the protective sheath that skins the EPP foam
. If I knew this was going to happen I would have wrapped it with medical ace wrap wile the glue dried
