Here's the latest.
Original symptom was at WOT throttle engine would peak and slowly lose rpm and quit.
Could not tune that out with the needle.
At the low end, it was sloppy rich.
Could not tune that out with the needle either.
At that point, and
before today here's what I did.
Nothing below made any difference in the symptoms above.
Different IBEC
Rebuilt DLE carb (New Gaskets, Screen and Diaphragms all around)
New Carb
Trued up the reed cage and carrier as they were not true/flat. At that point the reeds would hold water and looked good.
Things I tried
today.
New stock ring. (Waiting on a Bowman)
New Ignition
Different Ignition Battery (Hooked Direct)
Different Hall Sensor
Different Fuel Tank
Different Fuel
AC Delco Gasket Coating (In case of air leaks)
The only thing I haven't tried are new reeds.
Not sure at this point it's the issue, but I haven't tried it.
I'm kind a worn out
I haven't flown this plane regularly, but in the past it has been fine.
Don't remember exactly when the issue became apparent, but during the summer I remember
a day at the field that was very windy.
Since this is a big profile, upon landing and while idling, the wind picked up the hind end and it went
a$$ over tincups just sitting there.
Maybe the fact that it was running at that point, did something to the crank position.
A proverbial prop strike.
Not sure whether or not to send it in, or pack it in
Thanks for all of the help, support and ideas.
What a long, strange trip it's been...
Take care
Bob
