Just installed the throttle servo and also, screwed on the headers.  The servo mounting screws are aluminum, they are 1/3rd the weight of the steel screws.
all I have to do now, is connect the fuel lines, and set up the choke lever, then I can install the bottom cowl.
Then I will install the servos to the rudder and elevators.
The radio, was easy to do. I just copied my Dalton 300 ML, and made a new model, and renamed it Dalton 3oo SP.
It has all the mixes, alarms, voice activations with switches, low idle switch, and logical switches, and this can get adjusted as I go along.
I did reset all the servo sub trims to zero, and all the travel to 125 both ways.
