The rear of the cowl is supported on a piece of 1/2" plywood that has a threaded pipe flange and pipe attached, the wood is cut to approximate shape if the cowl.  The pipe goes through the nose bowl where a wood spacer is fitted to support the front, the pins are just keeping the cowl in place as it is rotated during painting.
When the plane was built some time ago, a 3W56 CS twin was fitted.  The plane was never finished.  When I decided to finish the plane last year I elected to go with a Roto 85 FS, same engine the Champ has, swinging a 26x8 in the Champ at 5600 rpm.  I picked the 25x9 because a 26x8 carbon fiber prop wasn't available.  The 3W 56 sits on the shelf, 17 years old , never ran.  Thinking about using it in the glass fuselage Cherokee build.
I'm using Randolph's Randthane which is a two part urethane based paint very similar to the Steward System Ekopoly paint.  Same procedure is used for both, dust on light coats until color saturation is achieved allowing each coat to tach up.  The final coat is wetted out to achieve the shine. When spraying the final coat it is sprayed with the same gun setting just moving slower and multiple coat until is shines, very easy to control.  The paint I'm using was bought the same time the 3w 56 was purchased some 17 years ago!
