@IMAC FANATIC  Are you Daves friend? I've been emailing him with a similar issue. I sent him a link to my site and instructions on how to properly setup the im22. I had an issue with my login on GSN so im a little late to this thread.  After I sent a few emails he also claims he now has it working great.
If you guys have any future issue with your products just contact the dealer you purchased them from or send me an email to
justin@vital-rc.com and I will help you out with anything I can.
I also told booma about the instructions on the im22 you guys had issues with so once I hear back from them I will update you guys accordingly but please see
https://duraliteflightsystems.com/index.phproute=product/product&path=154_151&product_id=476
or my site for the current operating instructions
http://www.vital-rc.com/store/p59/IM-22_INTELLIMATCH.html
Also posted below are some troubleshooting guild lines if you guys happen to need it, as always if you're not happy with booma rc and you purchased them through
www.vital-rc.com we will refund you 100% , please don't send back units that were damaged by the end user; we can tell.
1)The power must be on.
2)The button associated with the flashing LED is pushed.
a.When the button is pushed the servo input pulse position is ignored and the output pulse is frozen at the selected end point for few seconds to give acknowledgment feedback to the end user.
b.After the short period the servo input pulse is activated again so the user can readjust the endpoint if necessary.
c.This process can be repeated endlessly while the power is applied.
3)The endpoints are only remembered while the power is applied. As soon as power is cycled the end points are reset to factory. We do this so the user can start again if they are not happy with the previously selected end points. This is where the customer may be running into the issue.
4)After setting the endpoints and without cycling the power, to run the intelligent matching
a.The user should simply plug in the arming plug WITHOUT CYCLING THE POWER.
b.Once the arming plus is inserted, press the appropriate channel button to start the matching.
c.Pressing button I  will cause the IM22 to cycle between the endpoints and start matching channel 1 (A)
d.Pressing button II  will cause the IM22 to cycle between the endpoints and start matching channel 2 (B).
e.Note. You can only do 1 x Intellimatch routine with the arming plug inserted. The arming plug must be removed after the matching cycle is complete and power MUST be cycled to start the process for a second channel. This is a safety feature so a matching situation cannot happen in run mode i.e. during flight.
