3D "Extreme" makeover Terryscustom edition
Well I got a parking lot maiden on the Edge quick and it needs mixing, CG was a bit nose heavy and engine is a bit anemic for first run. I'm thinking it will wake up a fair amount after a couple gallons and some air warmer than 43 degrees. With my baffling the engine fins were only warm to the touch after landing.
I don't blame it. I don't perform well at 43 degrees either.;)
Well I have 10 flights on the Extreme makeover Edge and it's now balanced mixed and I'm having a blast with it. The new 92" Extra was maidened today and got three 15 minute flights on it. Mixing is all done and it is an absolute blast as it always has been. The extra 100 squares is noticeable with the 70 installed as it is just a bit more floaty down low. Perfect combination and feels super rigid in the air with the solid core wings and cored ailerons. Much less flex than stock built-up.
