Ok, first thanks to Kole and Limitless Aero for bringing these awesome planes into the US for us all to enjoy.
I bought mine from Kole, and met him in Houston on his way to Joe Nall to pick it up!
Once home, I couldn't wait to unbox and check it out. First, the coffin-like container protected everything perfectly:
The wings and stabs are really nice, and both have oversized control surfaces which will be tons of fun both in low/slow as well as violent spins and tumbles:
As you can see, nice covering work, and cool magnetic racing tips. Very nicely installed canister tunnel too! I also really liked that the covering was all pre-cut, and the pre-run (and installed!) pull-pull wires and links. I've built over 40 ARFs over the last two years, this is a first.
The cowl is a work of art. 'Nuff said.
There is no cheap stuff to be found in the hardware package. Nice multi-engine cutout templates, and all turnbuckle ball links and g10 horns. Even the wheel pants are sturdy and robust, and should easily survive flying off grass fields.
Finally, two other "above and beyond" stuff on this plane. First, high quality phonelic plate on the stabs for increased life and rigidity, and second the painted aircraft name on the canopy & vinyl on the fuse.
