The canopy isnt recessed, but it is fiberglassed in 1/4" over the shell and all the way to nose of hatch, the edges where it curves to the top plate are recessed slightly into the balsa, I built it up from underneath and sanded a groove into it so it sits a lil more flush. The canopy where it fits the deck was cut to the angle and sanded the edges so it wont cut from vibration and sits flat. Used zap goo to secure from inside with a large tip syringe to make a bead. Was glued in two sessions,  first the sides and rear, dry, and then the inside.ill use some filler to smooth out the canopy to hatch joint before paint.
Ill take some   close ups tonight n post so the words make sense. Took alot of time and thinking but I couldnt see using tape on such a good looking plane, although ive seen it done very well.
