IMAC Delro Raven 3.1M build
Jlc;12984 wrote: Wish I was going faster but I'm feeling my way through it. Control horns next.
Don't feel bad, I haven't worked on my build since the middle of July. I guess when I get started again I'll bring the thread over here.
IMAC FANATIC
40% happier than most folks.
I've been working on mine 13 months now, ya know, I dont think id want to fly or buy a plane that was turned out in a short time, professional builders excluded from that comment, every thing ive rushed through in it, I wasnt happy with.
Like to see that bird finished Jet.
IMAC FANATIC;13010 wrote: I've been working on mine 13 months now, ya know, I dont think id want to fly or buy a plane that was turned out in a short time, professional builders excluded from that comment, every thing ive rushed through in it, I wasnt happy with.
There has been other stuff clogging up the workbench including a helicopter of all things. But, I plan on getting back to it very soon. Threads like this and yours Brian keep me motivated.
Jlc
Jetpainter;12995 wrote: Don't feel bad, I haven't worked on my build since the middle of July. I guess when I get started again I'll bring the thread over here.
For sure bring the thread over when things get cranking again.
Jlc
I need to order hinges but I'm still debating flat or robart. I saw two threads both cardens that used flat style that looked really nice.
IMAC FANATIC
Dubro flat with piano wire running entire length . I used robart, much easier for me to install, but when dave ( dwdixon) put his in.. I was jealous. Much tighter tolerances.and the wire fills the gap, zero sealing to surcaces . Were building in same shop, theres ALOT to be jealous of on that plane lol.
Jlc
IMAC FANATIC;13071 wrote: Dubro flat with piano wire running entire length . I used robart, much easier for me to install, but when dave ( dwdixon) put his in.. I was jealous. Much tighter tolerances.and the wire fills the gap, zero sealing to surcaces . Were building in same shop, theres ALOT to be jealous of on that plane lol.
Thanks, I figured robart would be easier. Piano wire the entire length everything would have to be dead on perfect but I bet it looks nice.
IMAC FANATIC
Robarts are super simple, and your right it has to be dead on flush and level to pull it off right, s' why I went with robarts, maybe next time when im a lil braver.
Um, yea! All the builders are here now!!
Nice looking plane jlc! But pre sheeted foam.....that's just cheating! For your control horn blocks there are a couple of good ways. I use square blocks of balsa hardened with thin foam safe ca and installed before the hinge-line stock. Then install the horns with epoxy....ARF style. I know Henry Piorun did it with some built up blocks with balsa and 1/16 ply if I remember correctly. That was on a carden pro. I'm out of town flying for the weekend but can send some references when I get home. Most of my pics are on "that other site". I posted pics there on a hyperlite slick thread most recently for control horn block installation.
