Yes. They are machined with a tight fit into the arrow shaft. Epoxy is spread into the shaft and onto the threads and then pressed together. One test piece was made beforehand to see if I could pull the bushing out of the arrow shaft. At 250lbs I quite could not pull it out.Does the threaded end get glued into the arrow shaft?
