Madinpensacola
Not to worry.....I can't get any one to take pictures either! lol
  There ya go.  Took this surveillance video of you while you were napping at the field with your "friends" sitting around and "talking".
Oh okay, fine...
Oh okay, fine...![]()
 Please don't tell any one
That sounds like a good place to start if it quit in an up line. I'm guessing since you were about to do a Pop Top that it was wide open at the time?So I broke my 30% Carden Cap232. Was just flying around getting a feel for it as we had 10-12mph winds blowing. At the north end of the runway I went into a wide open throttle up line and was going to do a poptop. Right as I was about to start the poptop the motor quit on me. 7th flight and no issues at all on any other flight. Well I had plenty of altitude and was up wind. Leveled the wings and had that heavy wind pushing me. Wasn't about to try and turn to make another approach so I just floated it until it touched down. One bouncy then hit again and nosed over. Only minor damage. When the rudder smacked the ground it flexed the fuse and cracked the sheeting on the left side right at the back where the canopy meets. Didn't even break the prop. Will fix it in the morning when I get home.
Still trying to figure out what caused the motor to quit though. A guy that was there with said he thinks it might have gone lean as it was about 20 degrees cooler than any other time I have flown it. I will pull the plug in morning to check it out and see how it reads.
Yup was WOT.
Had a similar with a 35cent. Was 3/4 stick entering and dead stick leaving the attempted maneuver. Engine died when I throttled all the way down once in to the rotation. I'm pretty sure it died because I forgot to idle up after take off. Now I always idle up at the start of the take off roll. Glad you can get it in the air soon.
Interesting thought. I do not have an idle up on mine though I just let it always have a high idle.
