Finally got time to fit the large proflow canister. Looks like I'm going to need to shorten the 2 into 1 by 1-5/8" to get everything to fit into the 93" Laser. Does anyone foresee any adverse issues that would arise from shortening it that much?
@Kevin-Young thanks for the input. I was able to get it to fit without cutting the pipe down. I cut the tunnel instead...
View attachment 27222 View attachment 27223 View attachment 27224 View attachment 27225
Do you know whether the Large Pro Flow Canister will fit in the AJ Laser 93?Sorry I have been a sleep here. Very busy these days in the shop. The 2 into 1 set up works great on a Large Pro Flow Canister or our large Smooth Pipe. You will see a little larger gain running 2 pipes as opposed to only 1. Either way the new DA-70 is a good little engine and has sky high potential.
Dave
Sorry, I entirely missed post #26. I'm going to give it a try.Do you know whether the Large Pro Flow Canister will fit in the AJ Laser 93?
