les2097
Bart,
Don't wire it up and test for spark without first grounding the cutoff plug braid wires to the engine... you'll blow the Hall effect sensor...!!
I know this from experience... The caps have to be fixed as I said ... !! I too was interested in the engine... and when I saw your pics... the caps and the mufflers ... I am a bit less interested... Looks like the one muffler pipe was welded back on by someone who has an issue welding aluminum...
Thanks for GSN ... and I've used your computer power supply knowledge many times....!!
Larry
Larry
