PVA works great, but as per the instructions on most PVA you need to put multiple coats.      If resin stuck....there was not enough PVA.       The only way resin can seep under tape is if A:  The tape is crap or   B:   The tape was not pushed down nice and tight along the edge of the cut or     C: The gap was not pulled tight when taping the two halves together.      For an added safety line a person could also use fineline masking tape along the edge.
Point is, the wetted out cloth should not be dripping wet with resin when you put it on, just "wetted" out. Lightly tap it in place without trying to smash it down and resin will not go through. As a last call preventative measure a guy could always put about a 1/4" brush of PVA on the outside as well. Test it though as some china paint does not like alcohol.
