Header Tank pros and cons.
I have a similar set up on my gassers. I just use a large volume filter with a brass micro element.
Here is the photo. You run your vent line out of the main tank into a clunk in the vent tank. The vent tank has a line going outside the fuse as normal. When you fill the main tank, stop before fuel fills the vent tank. In flight the vent tank may fill a little, but it will get pulled into the main tank as the fuel level goes down.
I was surprised at how much cleaner the bottom of my plan was after converting to this method
I'm a firm believer of if something works with no problems, leave it alone. And though the header tank is kind of a cool idea.... I still like keeping things simple. Less fuss and less to worry about, less to have fail. But cool idea.
Good thing Toledo show is coming up in a few months. Time to find some older Hayes tanks, between 6 and 11 oz in size. Would be a great buffer size for that one enjoyable flight when the timer goes off too soon.
I wanted to do this 2 years ago, but I never found any 6 to 11 oz tanks at the show. Just forgot bout it last year.....
Ohio AV8TOR
Just Do It
disregard I just saw my answer
I like it. What sucks is I recently through away a bunch of really small glo fuel tanks. They would have worked perfectly for this application.
James (and anyone else that needs one).... send me your address. I have two large boxes full of smaller tanks I will never use. Might as well put them to use!
Installed the 2oz tank yesterday. Cannot wait to find out how it does. less than 1oz of added weight.
IMAC FANATIC
40% happier than most folks.
Installed quickfire filter /fuel balancer. Not really a header tank but holds 1/4 oz of fuel and good size element. Like the idea of ready fuel supply with 3 line system for starting and a lil extra fuel on a really long downine.
It would have to be a really really long downline to grab a bubble even with a traditional system though. But that the heck, gives another reason to bling something.
