After pondering why my engine deadsticked, having a little tuning troubles, I decided to clean the carb. Other than a little bit of junk in the screen , a little reside from a needle - it seemed fin to me. Slapped it back together and went back to basics. GP-76 screws are both set at 1.75 turns out. Reset and went to the field.
Ran ok, little bit of smoke in the exhaust, worked it's way up to WOT. Sounds Rich to me but ran pretty good. Used Terrys engine tuning guide and closed the LSN a bit, and found my little hesitation gremlin from before. gentle, but it was there. Opened up the HSN and it went away but the throttle response wasn't as good. Still not bad at all and much more reliable. so I said good enough for a flight.
Flew it three times, nothing but smiles and getting more and more comfortable with the plane, on the deck, tail tickling the ground. Awe yeah..... until my fourth flight. Mid throttle after flying IMAC for a bit, in a down wind gentle climb the motor died. Just like before. Once again Altitude was my friend. I was able to to a quarter pattern downwind turn to a perfect landing. A squirrel (non-flying type) may have abandoned tree at one point.... got close fellas. j/k!
As soon as I landed I ran the engine, not one single issue. This seems to happen to me a lot. Feeling a little defeated. Doubt it's overheating, not a low idle issue (also using a idle up switch), 8min into my flight, flying into breezy air from a glacier, so hmmmm. Fired up after four flips on the ground, and no issues through the run up, engine now has about 2 gallons though it and still emitting some black break-in goo from the pipes. I did notice when I took the canopy off it was warm inside which makes me wonder if I need to open up the cowling more or another panel in the fuselage for air to exit.
It's strange to me that it ran great for three flights and 8 min into the fourth when this happened again. I'm thinking it may just be getting a little too warm in the cowling. Plane sat for about 10-15 min before the last flight as well. Acts almost like I hit the kill switch  - running perfect for almost 50 minutes today and the half way through a flight just dies. hmmmmmmm
I know this isn't an engine forum. but might open it up a bit more under the hood. Plane flies great. I do think it may be a little nose heavy still though.
Also switching to tygon for the fill line helped. The line stayed in the last four flights, and also grabs to the fitting better.
