I worked on the fuel system last night. I didn't expect it to eat up my whole night and not be finished, but I guess I should have known better.
I realized life would be easier if I would finish installing the homemade canister mount before the fuel tank mount. The canister mount still needed to be deburred and smoothed out before it was installed for good. So, a file, some sandpaper, and a wire wheel in Dremel took care of that. The canister mount is in for good now I hope.
I mounted the fuel tank bracket and routed all the lines where they need to be. It took some time trying to figure out where the vent tube exit was going to go. As much as I like running canisters, sometimes the canister tunnel makes running the vent tube a pain. I decided to make a small aluminum bracket and use a fuel tank fitting for the exit. I then had to make a brass strap to hold the Tygon where is passes through the tunnel so it wouldn't touch the canisters.
All I need to do now is plug all the lines into the tank and strap it down.
