Gotcha the picture makes the holes look bigger . Are you using two temp sensors and are you placing them on the back cylinders
Hi
@Rusty 73 ,
I am using 4 temp sensors, one for each cylinder.
This picture is to demonstrate the ignition cables. If i were to place the front cylinder cable thru the rear hole, that is on the MB side, then It would be under tension.  I do not like that, so I made two small holes on the FW to accommodate this....
For the forward cylinders, this allows the cable to have plenty of breathing room, it will not be under a stretch.
rear has plenty of slack...
This is how I place the temp sensors.  Loop them over the highest most inter-fin area, so that it is as close as possible to the spark....
Being that the motor has a baffle plate, the hottest area would be not in the back, but on the bottom of the cylinder, so this is where the sensor is placed.
Here is the end result.  one sensor per cylinder.  We will see how this baffling set up works. This will be the 1st time I baffle a quad without a shroud.  SO will be interesting to see what the temps are like...
