LOVE'N DESERT AIRCRAFT!!!
I was just thinking, I need a 4cyl for my next plane. I always come back to the 200 but really thinking of some other engines to. One thing I have always considered is bearing life. Now if I get charged for new bearings for an engine under warranty because they are a wear item, my direction may lead more to a different brand. If I go in knowing I may have to pay for bearing replacement the on that engine, might as well save a few dollars right off the bat.
fasignation
Pretty much every gas engine is 28* BTDC +/- a degree or two.
I've got two twin engnies (a da120 and a dle60) the dle60 runs like a sewing machine but the 120 runs like s**t! I've rebuilt the carb twice and it's exactly like Walbro says it should be. I've tried two different ignition systems (both CDI/Rcexl type), I've set the timing dead nuts on 29 degrees but still the 120 runs really bad...especially in mid range. It will start, idle and run wide open but the mid-range sucks! Nothing I seem to do with the needle valves seems to make any difference. Midrange burps, burgles, 4-cycles and does everything but run smooth. Please advise...what am I doing wrong?
@fasignation Some good info put out in your conversation and I apologize for jumping the gun a bit and not seeing this thread post. Your ASL being you live in OR. is helpful info as well and like what @Jetpainter asked is helpful. Hope you get it worked out.
Also the temps and humidity conditions (weather) are good info in trying to help. Even with this said if it is not running right just send it in to DA and have them look at it. Even if it has the RcExcel ignition. Warranty or no Warranty.
Bartman
Defender of the Noob!
like @49dimes said, give DA a call, ask them and send it back if you have to. DA probably has the best customer service in the RC industry so help is just a phone call away.
Welcome to GiantScaleNews.com by the way! Glad you found us, if you like what you see please tell your friends. :)
