For me the way that I enter them is I will slow my plane down to just above a stall and then I will start pulling back on the elevator to push the tail down and bring the nose up. Once I have a close angle of attack, I will push left aileron to begin the plane rolling left. As the wings come from level to 45 degrees before vertical I will start adding right rudder continuing the role holding the aileron hard over the whole time, I will start relaxing Rudder and implementing down elevator. Continuing the role when the plane comes out of inverted and the left-wing comes to 45 degrees, I relax the elevator and start pulling in left rudder. Has the plane continues to roll and the Wings come back towards level I will start relaxing left Rudder and start implementing up elevator. Rolling to the right is just the opposite of that. You start with right aileron go to Left Rudder down elevator right rudder up elevator. Sometimes you will have to give a burst of throttle to keep the nose attitude correct with the angle of attack you want. I am no expert by any stretch of the imagination. That's why I still do them up high. But they are getting so much easier when you just don't think about it and just like Nike says, just do it!
Have a. Good day flying not good weather around me.View attachment 105123
Brrr.... just a tad on the cool side this morning. But I'm now on vacation. Just not going to waste any day light. Taking the red headed beast Edge out for a date.
I'm going flying!
You need a Crack Yak! super easy way to learn this is on a foamy. They are close and slow enough for you to make a correction.Prop hanging on sim is doable but I am struggling with what I belive it is called a-harrier. This is rolling the aeroplane slowly across the field at low height and tilted up at about 45 degrees. If it is can someone give some pointers how to get started because I am have difficulties with this one. Hay guys I haven’t even got to the field with this one yet.
I like to tell people to do a slow roll, with every pass slow the plane down, You will then see what input you will need to keep the plane flying in a strait line (like a four point roll, except it's a smooth roll). Keep slowing the plane down until you are eventually forced to keep the nose high to maintain a strait line ie: high alpha. Congrats you are now doing a rolling harrier. The circle will be the biggest challenge, once you get to about 2/3 you will rely on your muscle memory to complete the circle until you are proficient. The plane will want to roll left or right naturally depending on the direction of the roll. This would be the Rolling Circle. I have a hard time rolling right, P-Factor makes it easier to roll left and its more comfortable to me for now.
One of my goals very long ago when I started flying was to be able to do a good slow roll, but back then I always sucked at them. I spent a lot of time a few years ago on the sim and at the field trying to get reasonably good at them. I think it teaches you a lot about airplane control. Being able to draw fairly a straight line no matter the airplanes orientation is cool and leads to all kinds of neat things. Ridiculous crabs and slips are a lot of fun and it's something I learned as an offshoot of slow rolls.You need a Crack Yak! super easy way to learn this is on a foamy. They are close and slow enough for you to make a correction.
Hmm, maybe I will join you. Well, in a manner of speaking. I'll be out here in Idaho. Hee heeIt's supposed to be hot, humid, and nasty tomorrow......... perfect day for flying! Well maybe not perfect, but I'm going anyway.
