3D PAU 100cc EXTRA 300sp
3dbandit
mooneyrocket;10435 wrote: You'll want a 32oz for sure with the 120, especially if it's a new motor. I can only get 6-7 minutes max on a da 50 in my p-47... I'd go with a 32, and you can fill it half way, it doesn't make a difference.
I've had this engine for 2 seasons and know it well. I will be fine with small tanks.
3dbandit
To seal the hinges, I am using white ultracote.
3dbandit
Ailerons and elevators are now hinged and sealed.
Available throw:
Ailerons- 60*
Elevators- 65
I'm not sure if the control horns and servo geometry will allow me this throw. We shall see.
I used 6 playing cards for the hinge gap on the ailerons, and 4 for the elevators.
3dbandit
Tonight I began painting all the exposed wood with finishing resin. It is going to give the wood a nice shiny amber(ish) finish as well as semi-fuel proofing it.
Pics to be posted when dry.
Islandflyer
3dbandit;13468 wrote: Tonight I began painting all the exposed wood with finishing resin. It is going to give the wood a nice shiny amber(ish) finish as well as fuel proofing it.
Do you use Polyester Resin, or Expoxy Resin?
3dbandit
Islandflyer;13488 wrote: Do you use Polyester Resin, or Expoxy Resin?
Epoxy. It won't completely fuel proof it, but if have a small fuel spill it wont get all over the wood and damage glue joints.
3dbandit
Before finish
After finish
