Hangar 9 super cub
Spain
1/8" by 16" long A buddy put ends on for me so they hooked on the screws.
I had to tinker with the wraps a couple times but they have been perfect since I found the right tension.
Happen to have pics or link to source for the ends/hooks? Planning to finally make this change this Spring and 2 local friends just picked up the PNP model, so I'll make up a few sets.
Cheers
Lachlan
T
Cheers
Just look for "hog rings" and a pair of hog ring pliers. Total cost should be $15 or less for a bag of rings and a pair of pliers. Loop the ends of the bungee and crimp a ring on and you're done. Or ask me nicely and I'll make you a couple pairs of bungees and send then to you. :)
Spain
I've been able to find the shock cord and the hog rings, but the smallest rings I've seen are for 3/8" chord Still looking for the tiny ones!
Lachlan
The needle valve and carb assembly on my ASP FT160AR is terrible. I just ordered a carb and manifold assembly for the O.S. Ft-160 from Tower Hobbies. If it doesn't make that engine run more consistently then I'll be upgrading the powerplant to something more reliable, like either the VVRC 40 or something in a gasoline four stroke selection. So frustrated. The low speed needle needs to be adjusted every couple hours of run time. Ridiculous. Anyone have a good gas engine for this Super Cub that fits inside the cowl without any cutting? (That's a requirement for any engine I end up with on this airplane!) :)
Lachlan
once it runs, that ASP 160 should sound awesome in a cub.
It runs fine, and sounds amazing. It just needs constant low speed needle adjustments due to a poorly designed and engineered carb. It should run more consistently well with the OS carb.
Lachlan
Welp, damn. The O.S. Manifold won't work unless I fabricate some longer intake tubes. Ant worth it. I think I'll just put a VVRC 40 in it and call it done. Anyone want to buy an ASP FT160AR that runs good, but not quite well enough to haul a 20 lb Super Cub around? :)
