joshgluck
Just get with Noll and get it replaced.
Thanks Jim
Since I'm new to electrics I wanted to make sure it wasn't something I was overlooking or a known issue. I'm sure Noll will help me out.
Thanks Jim
Honestly sounds like the shaft pulled through the base slightly, and when spinning allows the front of the magnets to grind on the stators.
So you think if I pull the motor is might be able to tap the shaft and reset the set screw or better to just call it in for replacement?
That is true - they are supposed to be the same from the wings back...but the fronts are very different.
What would be really cool is if they combine the two versions into one, and make them like the 74 Edge, 72 Extra, and 70 Velox... just toss in a firewall extention for the E-power, and make all replacement parts the same.
You're going to have to pull it off the plane anyway, might as well look and see if the shaft is loose.
