Good evening Gents,
I have made a little progress on my Yak in that the servo mount in the wing has been fixed, so that's one more thing crossed off the list. Unfortunately, as it sometimes happens, I forgot to take any pictures. . . . ..
I do have a question I'd like to run by you Fellas. Since this is my first true giant sale plane, it is the first time I've had a spinner that is screwed into the side of the backplate in lieu of the usual bolt through the tip of the spinner into the end of crankshaft. Both spinners are also cut for each prop. I believe this tells me that I will have to use the prop as a guide to drill the backplates so I keep the prop blades centered in the spinner openings. I can use my drill jig to keep the prop and backplate centered, but what do you guys use to hold the prop to the backplate to keep it from moving while you try to drill the first hole in the backplate? Would something like two sided tape work well enough or do you guys have any better ideas?
Thanks Gent's
After grinding the spinner to accommodate the propeller, I carefully put my backplate, and pre-drilled (by me) prop on the engine for alignment and then used a drill bit to transfer the hole locations to the back plate. Then used a pilot hole, followed by the actual bit size - I double checked my alignment with the drill guide. After drilling one or two holes, you can add your drill guide to the prop/backplate stack and finish the last few holes up if you want. It's tricky for sure, I'm sure someone else has a better method... but that's what I did.
.  Thanks for setting me straight
