Scale 50% Dalotel 165
Make sure that you have the correct Viton tubing I bought some from my LHS and it look good and everything else but it failed with in 3 minutes into the flight. The tubing split and came off at the most inopportune time. Banged up the plane pretty good. It seems that I got some stuff that was not meant for us rc guys. I belive if my memory is correct the good Viton tubing came had from PSB hobbies. Please somebody correct if I am wrong.
Ya I hear you, I am having my doubts about this one, so will have to look into some good proven stuff, thanks for the heads up
PSP Mfg. http://www.pspmfg.com/FuelLine.html
installing the choke and throttle servos, I know not the ones I usually use but had these, and they are high voltage so its all good
