Hi @thurmma , I found it;
flight date: 2/28/2015
flight number # 31 on the DA 200
number of gallons thru engine = 10
Engine: DA 200 ML
Fuel / oil mix: 40:1 redline
altitude: 260 feet
ambient temperature: 35 F
prop size: Falcon 3 blade 29 x 13
air frame: DALTON 300 ML
radio system: JETI
data:
1. high temp during flight (not after landing):
RIGHT REAR CYLINDER 208.9 F
LEFT REAR CYLINDER 181.3 F
RIGHT FRONT CYLINDER 249.2 F
LEFT FRONT CYLINDER 228.1 F
2. temp range (see 1 above)
3. rpm range 1080 to 6600
4. rpm max during flight 6600
5. rpm max on the ground 5990
6. Rx voltage 7.6
7. Rx voltage minimum during flight 7.5
yep, your ZDZ is a power monster!!
I used a Falcon 3 blade prop, same dimensions as your Mejzlik 3 blade. Hard to make a comparison apples to apples, with size, when it is different manufacturer.
Engine: DA 200 ML
altitude: 260 feet
radio system: JETI
data:
6. Rx voltage 7.6
