Ohio AV8TOR
Just Do It
As a long time scratch builder I can tell you what the problem is with many manufactures use of Robart hinges. I had two pull out on my 87" 3DHS Extra. First look at the hinge there are barbs designed to trap epoxy and make a mechanical lock with the epoxy and as you get closer to the hinge pin there are no  barbs and in fact it is tapered of in essence it has draft. After I removed the elevator and cleaned out the holes I notice that in the location of the hinge there was not enough wood backing to even get to the barbs, it was all held in the taper section. This really bugs me about the modern designs that use Roberts as they don't have enough wood back there.
