Maybe a little help for those that may be experiencing some servo "jitter" from Hitec 79** servos.
35% PAU Extra 300SP/Hitec HS 7954SH/HV all control surfaces.
40% SD Models Extra 260/Hitec HS 7954SH Ailerons and Elevators/HS 7980TH Rudder/HV
42% Hangar 9 Sukhoi SU26/Hitec HS 7950TH all control surfaces/HV
Other than low audible "centering sing", servos are quiet, quick, accurate and very powerful on HV setups.
Here are also a couple of ideas to help with servo jitter. I use Smart Fly Power Expanders on my large planes. I "only" point this out primarily because of all the features it allows. Plus, the SF boards also "BOOST" signal on the servo leads to help the "jitters" that some may experience.
Another little assistance item is the "Signal Boosters" that Hitec makes readily available to all Hitec servo users that may be experiencing "jitter" issues with their servos.
I was concerned with the extra long extensions I needed in the Sukhoi and possible "jitter" issues I had heard about. Not a single one used anywhere in the Sukhoi as I didn't need them.
Tanner,
@Xpress can give all the particulars regarding the use of the Signal Boosters from Hitec.
Hoping this will offer a little insight and perhaps a resolution for some of you guys out there.
