All the equipment is home made.  Here is the vacuum table, 1/4" plywood bottom, 1 x 3 sides and the peg board top, two shop vac's are connected in series to the table.
You need a buck to form the sheet over, this need to substantial, in my case I made the buck from a less than perfect canopy, this is going on a Bob Godfrey One Design that you may have seen in the back round of the Champ photos.  The canopy was fitted in a wood support and filled with Ultracal 30 plaster, then glassed  and sanded.  The plastic blanks are 24" x 32", get six from a 4 x 8 sheet to give you an idea of the size.
The oven is two 1500 watt Sunbeam quartz heaters housed in packaging from an Aeroworks ARF, the fiberwood stuff that looks like Masonite.  I will get photos of the oven when I do the pulls.  Making a canopy for the One Design and a new canopy for the Champ, the canopy I bought for the Champ was Ok but not quite what I wanted so I bought another canopy and made a plug from it then glassed and sanded to fix the problem areas.  I tried pulling a Lexan (Polycarbonate) sheet for the Champ last week but that turned into a mess, much more difficult than pulling PETG, pretty sure it would have been the bees knees if it worked.  I broke most of the equipment trying to make the pull including damaging the plug.  But hey I still have 5 - 24" x 32" Lexan sheets that I don't what to do with, I may try again once the dust settles from the Champ build.  Will post the following photos in Champ build once I get the plug repaired
