Been investigating my laser 73" "glitch" lots of forum research nothing definitive yet
One thing I was reading up on with the tech aero. For those running A123 batteries, what voltage setting are you at? Mine has no plug jumpers so 6.6 but that's the highest setting. Curious if when the battery is under load for a bit it gets a spike that is below 6.6 creating some sort of power loss?? Makes me wish I had a data logger in my tx! Far fetched but dunno.
My Tx failsafe was set to hold position.... from what I can remember it was holding its position the times it happened. Unresponsive model continuing on course for the 3 sec duration. This starts to make me think it's not a battery issue since the engine was running smoothly each time this happened. And this is supposed to happen when interference takes place.
Plus my lack of switch, deans to dual JR plugs, makes me believe it cannot be this. Ohm checked good too.
The receiver was taken out and put in a cub and has been working great. So probably not the receiver.
My clean and dirty side was separated from the start. Possibly one antenna too close to the battery lead.... but that's far fetched to me too.
Also found a report of this happening to another guy and it was a slightly loose ignition cap (spring installed), and put a hose clamp on it to fix  it. My engine is a new DA-35, doesn't seem as tight as per say my DLE-35 so might have something there? Going to investigate that a bit further.
I hate shotgunning parts!! It's very tempting to just throw one some new equipment though.
