thurmma
Hello everyone!
Does anyone know how to tell which version of the DLE-170 I have? Do you go by serial numbers, looks or both? Also, what are the changes between versions? I have heard that there was a reed issue with one version, but I don't know which.
This question is coming up because my 170 has ran flawlessly through about 4 gallons of gas and the last few flights, even before the re3's, it has been trying to lean out on an upline. I have opened up the low end just a smidge and the top end a lot, but it doesn't appear to make any difference at all. I can get the bottom end to run rich, but not the top end. I did get the engine temps down to about 215-225 on the ground after an extended full throttle run on the ground, but that is it. I noticed that the rpm would be great at the beginning of the run and then start to drop off after about 15 seconds or so. I will be doing some baffling over the weekend, but I haven't changed anything on the plane up to this point and it has ran great.
Any help will be greatly appreciated.
BTW, the plane is a 3DHS 120" 330LX. Also, running premium ethanol free with Redline at 30:1.
