Time to add stringers so we started with the aft fuselage section.
The holes in the stab mount need to be drilled on down through the hardwood blocks we added. To assist with getting these to be perpendicular, we used our drill press to drill holes in a piece of oak for use as a drill guide. This was clamped to the stab mount and the holes were punched on through. The fin was test fitted and looks to be perfect.
Next is the addition of the diagonal fuselage braces starting at the tail section. The next bay needs to have the elevator servo rails installed and then the diagonal braces. Since the servo is positioned off center, the brace on the left side needs to be keep out of the way to make room.
The stab was temporarily mounted to check alignment, looks good! Then the diagonals for the remainder of the bays were added.
WE are using the optional scale tail wheel and Gunny offers a detailed plan for installation. His addendum is available at Aviation Concepts and uses one of the Ohio Superstar assemblies. Hardwood blocks were added to the bottom of the last bay for mounting this wheel assembly.
The fuselage was removed from the building board and turned over so the internal access hatch supports could be installed and so that the wood screw that supports the tail post joint could be installed.
