		Got the motor mount and motor installed on my Wild Tiger profile tonight.
			Thanks bro.I will send some PM's later today mike. Looked through the build thread again and didn't see the CG referenced. As for mounting the flight pack we usually have them mounted vertically between the motor and the LE of the wing. ESC on on side and battery on the other and you can slide it back and forth to adjust the CG.
Thanks for the heads up. I have a Hacker A40 also. I might slap it on there if this motor doesn't work out.Looks great @pawnshopmike . Just my opinion though you might want to go with a little higher kv motor if running 4s. 800kv would be my minimum.
Looks really nice. But....but....but...., they do make lil gassers you can put on that. HEH HEH....just yanking your chain there Mike. LOLAlso got the receiver installed. It's inside the right wing.
