Naughty Monkey
Joe, have you had any planes that you have used aileron differential?
			I thought about extending the motorbox and not using an engine spacer. But, my flying buddy has a 4 cylinder that he thinks would be fun to try on this plane (after I get a few flights on the plane with the twin). So, I started in on an engine spacer. This is the longest one I've made... 2-3/4". Here is twelve pieces of 1/4" aircraft plywood rough cut. I actually only need eleven so one will get tossed. I still have to lightening hole them all and drill the four bolt holes in all of them. Then I'll epoxy them together, grind that hunk down with a drum sander, and finally seal it.
These 4-1/4" long bolts are not going to be long enough to get a locknut on the other side of the firewall. I'll need to order some 4-3/4" bolts.
You know Joe, if ya don't want to use that 3dub, just send it to me. I'm pretty sure I can find a use for it. Lol
I have only heard of using aileron differential to help with yaw while rolling. Now I am wondering if it might be part of poor geometry. If you did use differential, would you still keep the neutral point of the servo centered so you had equal degrees of throw and just move your horn location to get the differential you want?Pre protractor days I would use it on all my planes. Later I think the only plane I can remember using aileron differential was my CompARF with skinned hinges. How about you guys?
I do not use differential. Rolls very axial.Pre protractor days I would use it on all my planes. Later I think the only plane I can remember using aileron differential was my CompARF with skinned hinges. How about you guys?
