It's vinyl. It comes in several sizes, but here is one.
			Thanks for taking the time to take pictures of the process.I'm to the point on my scratch built Golden Age racer project that I needed to do a little glassing so I thought I would post it here. I needed to glass the hatch so I can finish the cockpit.
I started by filling any imperfections in the wood with Lightweight joint compound. I really like this stuff. It fills well drys reasonably fast, and is very easy to smear. I just use my fingers, nothing fancy. After it dried I sanded it smooth with 120 then went over everything with 220.
After vacuuming the surface clean and going over it with soft paint brush I laid my .5oz glass cloth out over it and roughly trimmed it to shape. I then used my soft brush to smooth out the cloth. I mixed up some Z-Poxy Finishing Resin (Straight 1 to 1 mix no thinning) in a paper cup and poured out a bead across the top of the hatch. Using a very thin, very flexible piece of ply that I have sanded very smooth I started pulling the resin down the sides. I squeegeed it out so there were no dry spots, but also no thick puddled spots. I trimmed the cloth at the bottom as I went to make sure the overhang was not hitting the table and pulling the cloth of the hatch. I continued this until I had a nice light even coat over the whole hatch.
One tip, I like to mix small amounts of the resin as I work. If you mix a lot it starts to thicken as you working and it makes it harder to get an even coat and it pulls at the cloth a bit. It really doesn't take all that much resin.
I had intended to weight the hatch before I started and forgot. Out of all the things I've lost, I miss my mind the most. Tonight I will lightly sand it and put on a second coat. I'll try and remember to weigh it before hand to see how much weight the second coat adds. In all my testing the second coat added very little weight.
View attachment 24440 View attachment 24441 View attachment 24442 View attachment 24443 View attachment 24444 View attachment 24445
Planking is a time consuming process but if you going to do a really curvy surface with wood it works awesome.You took your time planking that it looks good. I do exactly the same as you do the only thing I have difficulty with 1/2 oz cloth always use 3/4 oz cloth but the rest do the same. Also use west system both do the same and will use either. Now I belive you are in the paint business very interested you you are going to,paint it. The type of primer to link the epoxy ti the paint and the type of paint.
Looking forward to learning as you go through this painting process. I hope to get back on my Krill sometime in the next month or so.
At the glacial speed I work at it may be awhile.I would LOVE to do an all sheeted, glassed and painted airframe at some point. I'm excited to see Jetpainter's results.
I would like to know the difference in weight between an ultracote covered plane and a glassed and painted one. If it wouldn't be that much different I would go with glass and paint. Specifically a plane like Terry's viper kit, that is already mostly all sheeted. No more covering to mess with.I would LOVE to do an all sheeted, glassed and painted airframe at some point. I'm excited to see Jetpainter's results.
