Thanks everyone!  I'm really excited about it.  I will tell you one thing.  Changing the hinges from the fiberglass tape to the Robart Pins made it a completely different airplane.  When I was doing IMAC maneuvers for example, I had to make all of these little inputs to do what I wanted, and now if I want an inverted 45 degree upline I just roll it over and it goes... any little movement now is visible.  So it's a lot tighter and more responsive, if that makes sense.
I haven't given up on the canopy and cowling.   I sanded the cowling quite a bit, and then used 2 coats of white primer.  The orange that I used matched exactly in tests, but came out darker on the pieces.  I don't know what happened.  I know I can get a white cowling from Fiberglass Specialties, so I may try it, but ya'll are right, it almost looks like it belongs there.
