Next, test fit the fuse side assemblies and ensure that all areas fit snug and tight.     If there is something that does not fit correctly due to glue squeeze out etc. it is important to fix that at this time.
When satisfied, glue the fuse sides in place with wood glue. On this build I used wood glue on the longeron, clamped that portion in place, then glued all formers to the side one at a time with medium CA applied on both sides of the former. Again, no kicker was used.
