Decided to redo the OEM blind nut in the other wing. While I was in there I added a little tri-stock. Did the same to the other side.
Went ahead and cut some 1/2” bright yellow strips to gap seal the wings.... I took a break and then did the other wing... except I was so tired I put a second gap seal on one surface! Duh!!! Tried using a hole punch to give the hinge some relief. It worked great
Let me show you guys again how pathetic this blind nut was.
