The Tail Wheel looks different than the OEM one that came with mine. Post a close up pic. Im curious.
Will do when I get the chance. I painted mine black and adjusted the springs to be lower. They send metal brackets now where the springs attach so the plastic doesn't split like before.
That's what I was wondering... Metal steering arm.
Also is the fork bent/welded like my OEM version was, or CNC now?
in mm I'm curious if the new spring bracket will fit my assembly... Mine had a plastic bushing inside as well. If you have a caliper and can verify the dimensions for me that would be nice to know:
w/tailwheel off, bracket top to bottom with bushing in. Then the outside diameter plus the leaf spring that sticks out a bit aft of the bracket.
Yes I have XT 90 on mine as well started with XT 60 and while testing they started to melt, but the XT90 did the job. The only thing that I also did was make one of the XT 90 have a spark arrest, when connecting 12s the spark is pretty impressive so I changed one connector to stop the sparking.On another note, maybe you can help with this, @Snoopy1 I have never had to run a battery setup in Series of this large voltage before (12s). I am going to be running (2) 6s 5000mah lipos in series to power the 40CC Xpwr Motor. I want to make sure the series adapter I get can handle the voltage and amperage output that will be required. Do you guys think this connector is ample for the job? https://www.amazon.com/RC-Battery-Connector-Helicopter-Quadcopter/dp/B07JKNWN85/ref=sr_1_1_sspa?crid=XPQT8V51R7D2&dchild=1&keywords=xt90+series+connector&qid=1590508899&sprefix=XT90+series+,electronics,165&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyVzNGNThQVEdXUE83JmVuY3J5cHRlZElkPUEwMjQzNDQ2MTBUVU9KU0QwVVIxViZlbmNyeXB0ZWRBZElkPUEwODI5MDk3TTBTNExVWVdLMUxQJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Thank! -Clint
Gotcha. I’ll get those for you later this evening when I get back home. Up at the hospital getting X-rays done at the moment.@Snoopy1 you can buy the XT-90S that have the spark resistor built in.
@FlyingClint thanks for the measurements I really only need two.
Here is the 3mm T-Nuts from micro fasteners. Sooooo much more robust.
