I did a thing this morning. Should liven it up quite a bit.
Question for you spectrum guys. My UMX timber. Wanna make the ailerons work as flaps. They are both on seperate channels. How do I go about setting it up. Things look different from my old futaba or how I know to do it with my taranis.
Unfortunately I’ve only been able to do this with an Aura, where all the settings were on it and not in the transmitter.
Which model of Spektrum transmitter and does each surface have its own channel?
Yeah just a dx9 and each on their own channel though not sure which channels off the top of my head.
Wish I knew the answer.
Just downloaded the DX9 manual to see if it has the same features as my DX18. Looks like a combination of making a mix between aileron and flap, and assigning it to a switch, if you want both ailerons and flaps or full span ailerons. If you want only full span ailerons, then select the wing type as four aileron.
