		Are both colors the same brand of covering?@BalsaDust need some help. Did the glas method of joining Ultracote together it work great and you can not separate the two from one another. But ran into problem hope you have a solution. When the two pieces were joined the sheet of Ultracote was flat and smooth. Went to install on the elevator everything went well but when I went to shrink it down is when the problem showed up everything pulled nice and tight and the seems never moved glued solid but what happened is the seam started to corrugate and I could not fix it as soon as I put some heat to the seam to get rid of the corrugation the started to let go. Has this happened to and if so how did you fix it, thanks.
........Out flying again and engine was too lean on the top end. Went dead stick throttling up in to a strong head wind for a climb out (doing touch and go's) and plane came to an abrupt halt like it had brakes! It was only 4 or 5 feet off the ground. I applied down elevator to keep the nose down but the wind stopped all forward momentum and it fell like a rock on to the right tire. Also re- opened the crack in the cowl I repaired
. Good news is that's all that happened
 or even scratch it up.
